Seams
All  1  2-11
10245.2 In reply to 10245.1
I was able to solid the body but with many extra steps having to rebuild the troubled surfaces. In 30 minutes I will run into the same issue of seams appearing again elsewhere and this is what I don't understand because I try to work cleanly and follow tutorials on how to avoid errors and yet I tend to get stuck or break something.
10245.3 In reply to 10245.2
Hi Art, well it's not really an error to have those edges between things. It's true that it is better to not have them when it's easy but the ones you circled in your first post probably won't be a big issue.
What is it that you're planning on doing in those areas that you must have them removed?
You can have a solid with those edges in place, they don't have to be removed to get a solid.
10245.4 In reply to 10245.1
Hi Art,
> Furthermore the merge command does not appear to work as expected all the time. On one
> side of the model I am able to merge a split arc edge curve into one clean one. On the other side
> I am unable to perform merge and my arc stays split into two parts because of that other existing
> seam. Why would only one side of my model produce this vertical seam after performing a mirror
> whereas the other side does not?
Can you please post the .3dm model file with the edges you are referring to here that won't merge?
> If I mirrored and boolean union both halfs, the seam should go away?
Currently boolean union can remove edges in the combined object in 2 cases - when they are planes that are coplanar, and when the 2 faces have the same full underlying surface.
It doesn't currently know how to combine 2 side-by-side extrusions into one extrusion but that is something that I want to add.
10245.5 In reply to 10245.4
Guess I was referring to the ability to merge two edgecurves into one like you can on normal curves? Is nt not possible because of the nurb line running down the center of the model?
Discovered can simply assign a style to edges I find unsightly and simply hide them. Out of sight out of mind. Works for me. Going back to my original post, I guess I could have simply hid unsightly edges via styles. But I also wasn't sure if something geometrically was screwy in the nurbs themselves. Thanks for the help, sorry for the confusion.
EDITED: 23 Mar 2021 by ARTURBRZUZA
10245.6 In reply to 10245.5
Hi Art,
Yes that's correct - 2 edges can only be merged together into a single longer edge if they are the only 2 edges touching each other. If there are additional edges connected then it can't merge them.
No nothing is inherently wrong with that. It can be a good idea to have larger faces when possible instead of multiple fragments but it does not ruin the model to have some of those.
I do want to update the face merging for boolean union so it would merge the cases you showed.
You can also select them and use Edit > Hide without assigning a style.
You can try this script by Max Smirnov!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.4
in this image following curves are managed before the extrusion...
In this one curves are managed directly...
10245.8 In reply to 10245.6
Micheal, thanks for your response. Like how there are multiple solutions here. :)
10245.9 In reply to 10245.7
Interesting PILOU. I have not gotten into using scripts quite yet but will try this out soon. Only gotten as far as setting custom hotkeys :)
10245.10 In reply to 10245.9
Precision...
code: (only one line)
var fs=moi.filesystem, fl=fs.getTempDir()+'tmp.stp', gd = moi.geometryDatabase; gd.fileExport(fl); gd.removeObjects(gd.getSelectedObjects()); gd.fileImport(fl); fs.deleteFile(fl);
Copy the Max's code in a .js file, and save it the "scripts" directory. (with any name you want without space )
Also the "commands" folder is ok.
To use it, simply select the curves you want to elaborate and run the command.
Load the file and put it in the scripts folder of Me (if this folder does not exist, create it)
Make a shortcut, or press TAB and write the name of the script
Select curves and call the plugin.
10245.11 In reply to 10245.10
Thanks PILOU, looks pretty straightforward.
Show messages: All  1  2-11
