Obj object from nurbs
All  1-8  9
10244.9 In reply to 10244.8
Hi Tony, ok so I was a little confused by the Italian text in your screenshot above.
So in this one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10244.6
the problem there is that you've put in values for both "Divider larger than" and also "Avoid smaller than".
You can use "Divide larger than" to increase the amount of divisions, any poly larger than this distance will get divided.
You can use "Avoid smaller than" to decrease the amount of divisions, any poly smaller than this distance will get a rougher angle.
So with using both of those at the same time you're telling it to simultaneously divide things up more and also to not divide.
Don't do that.
Leave "Divide larger than" blank. It's used for different situations where someone wants to have a high poly count.
Put in a relatively small value (like 1, or 0.5 or 0.1) into "Avoid smaller than". Adjust the angle with the slider so the large pieces have a smooth enough density for you, and then smaller areas (below the "Avoid smaller than" distance) will be rougher which is what you want for making a reduced file size.
If you need more help or demonstrations it would probably help if you could post the model file. You can e-mail it to me at moi@moi3d.com if you want to keep it private.
Show messages: All  1-8  9
