Transparancy?
All  1  2-12
10243.2 In reply to 10243.1
Till now there is not real transparency but you have this script by Max Smirnov
script:/* Transparency */ var gd = moi.geometryDatabase; var so=gd.getSelectedObjects(); if (so.length>0) { so.setProperty( 'displayMode',1); so.setProperty( 'selected', 0); } else { gd.getObjects().setProperty( 'displayMode',0); }
Just select an object(s) and press the shortcut key!
You can do this on different objects!
Pressing the shortcut key again will make all objects reappear!
So always select an object before calling the shortcut, otherwise all objects will reappear!
10243.3
A glas material would be the hit.
10243.4 In reply to 10243.3
Maybe on the V5 but i believe that will slowdown the display! :)
10243.5 In reply to 10243.2
Thanks - while not what I was thinking of it still looks useful.
Frederick
10243.6 In reply to 10243.4
It seems the nature of the universe that all things have a cost in proportion to their desirability.
Frederick
10243.7 In reply to 10243.6
Cool maxime! :)
10243.8
better then Impératif catégorique.
10243.9 In reply to 10243.1
Hi Frederick,
> Could the way MOI works allow for the implementation of transparent objects?
Unfortunately no, not easily. The regular video card display pipeline does not allow for transparent objects without special processing which can reduce performance considerably.
10243.10
Perhabs, you could switch transparency off and on.
10243.11 In reply to 10243.10
At some point there will be a simple "off-line" renderer built in to MoI and that's where it would be possible to do transparency.
it's not a good fit for the real-time viewport display though.
10243.12 In reply to 10243.9
I rather suspected that would be the case.
Thanks.
Frederick
Show messages: All  1  2-12
