Convert joined surface to solid
All  1-4  5-6
10242.5 In reply to 10242.4
Hi Frederick, I tried several other programs including Rhino, ViaCAD, OnShape, and SolidWorks eDrawings viewer, and none of them could import the file as a solid either.
It kind of looks like the file is made up of a pile of individual separate surfaces, which is a problem in this case because there are several different parts in the file which have some areas touching so it's difficult for an automated process to figure out how to join the surfaces with just the ones that should be an individual part.
Also it appears that there are a few missing surfaces as well.
So the process to get this into several solids will probably be to use Edit > Separate to break it into individual surfaces, then select a set of surfaces for one part, join just those together and then construct any missing faces and join those in as well.
10242.6 In reply to 10242.5
Glad to know it wasn't something I had done wrong.
I will continue to re-create the parts in MOI and all will be well.
Frederick
Show messages: All  1-4  5-6
