Cannot open .step file. stuck at 100%
All  1-4  5-7
10241.5 In reply to 10241.4
it was some trouble on export
10241.6 In reply to 10241.3
Hi Dmytro,
> Thanks Michael, you right. it was opened after few hours, not so fast :)
> CAD Assistant opens it in 43 sec
If you can send me the file at moi@moi3d.com, I could then test it with a profiler to try and figure out what is taking so long and see if I can fix it.
If the objects are unusually large or small it could be an intersection tolerance problem with a tolerance level that is too tight.
CAD Assistant can be helpful for file translation, if you import it into CAD Assistant and then export out from there as a Rhino v5 .3dm file then that can probably be loaded into MoI easier. For .3dm format MoI does not have to process the trimming boundaries like it needs to for STEP import.
10241.7 In reply to 10241.6
the letter has been sent
Thanks for tips!
Show messages: All  1-4  5-7
