Antialiased and sharp viewport - tutorial
All  1-6  7-9
10231.7 In reply to 10231.4
Hi Andrew,
> Second question: Could I install two instances of MoI3D on my PC, one without the tweaks associated
> with it to ensure accuracy, and a second with the tweaks for those times when I want to do a number
> of snapshots?
Maybe, it depends on how the video driver is set up. If it sets things up based off only the .exe name then it would end up applying the same settings to each install.
10231.8 In reply to 10231.6
@Pilou,
> I believe you can't to run these "two" different installs of Moi for run them on the same time!
You can do that, but if the video driver controls its settings by the .exe name that will be the same between both installs.
10231.9 In reply to 10231.8
Thanks for your replies. I will try the script out. I've seen it metioned in the forum before but never remembered to set it up as I rarely use any scripts!
When I'm on the PC I'll experiment with the graphics card settings and two installs.
On my laptop, I've now got two instances running. One is from the original MoI.exe in the MoI 4.0 folder, and one from a clone called MoIC.exe running from a duplicated folder called MoI 4.0C. I even changed the shortcut icon to launch the clone to the old Windows Fax Service icon, as after all that made clones of documents! It may be enough to fool the Nvidia settings.
Andrew
Show messages: All  1-6  7-9
