Help to sove a car panel..
All  1  2-4
10223.2
See attached example. It may be better to run a couple of different sweeps since the body lines are fairly well defined and would be difficult to add later
Size: 34.6 KB, Downloaded: 57 times, Dimensions: 800x544px
10223.3 In reply to 10223.2
Thanks Grendel,
It's a tricky shape to make. Your idea with using sweeps also works.
I'm trying a mixture of this with also booling the wheel part - rather than trying to complete it with it there from the start.
About the surfaces...another method! :)
Curves / Extrude
Offset
Extrude
Join
and now you can modify the "yellow" surfaces alone or both to the form wanted
Show messages: All  1  2-4
