How to use Flow?
All  1  2-14
10215.2 In reply to 10215.1
Try with a rectangular (square) face as Start ...
You can also tale a circular surface as start but you will obtain some more empty aeras!
All is depending of surfaces / Volumes...
EDITED: 8 Mar 2021 by PILOU
10215.3 In reply to 10215.1
See:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4549.12
You'll probably want to read the entire thread.
10215.4 In reply to 10215.1
Hi Jack, there's some pretty detailed instructions in the help file here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
quote:
For projective mode the target object can be made up of multiple joined surfaces if they are all smooth to one another.
In projective mode, rays are fired out from the base plane along the base plane's surface normals and intersected with the target object. The target object should be large enough so that these rays actually hit it and do not just fire out into empty space.
Do you have an image or sketch of the result you're trying to get?
10215.5 In reply to 10215.3
thx, I will try it
10215.6 In reply to 10215.4
thx Michael, I just update my question, please have a review.
10215.7 In reply to 10215.6
Hi Jack, for your #1, one way you could avoid the deformation would be to flow curves instead of fully constructed tubes, then sweep a circle on the deformed curves.
For your #2 that's making a strange result because of this:
10215.8 In reply to 10215.7
thx Michael,
for #1, your solution is good, but it is time consuming, we need do each curve individually.
10215.9 In reply to 10215.8
Hi Jack,
You don't need to do each curve individually, in sweep you can select a bunch of curves as the rails in one use of the Sweep command.
Here's an example:
10215.10 In reply to 10215.9
thx, I just figure out, I need select rails curves in the same direction. if I select both horizantal and vertical, it will fail.
10215.11 In reply to 10215.10
Hi Jack, check the placement of the circle profile curve that is being swept. If it is inside the bounding box around the rails it will use the circle from its current position. If it is outside the bounding box around the rails it will use "auto place" mode where it will automatically move and rotate the circle onto the starting position of each rail. For this case you want auto place mode to be used.
If you're still having trouble please post the 3dm model file with the curves you are trying to use so I can see what you are running into.
10215.12
Why don't you use the same process as Michael for your little demonstration videos (post 10215.8 below), I think it would be more explicit.
https://www.screencast.com/
-Zooen
10215.13 In reply to 10215.12
thx, problem already solved
10215.14 In reply to 10215.12
@ Zooen It's not the same price and for 10 - 20 seconds that is the same result! ;)
There are a lot fo screen recorders but i prefere my very simple GifCam
https://moiscript.weebly.com/gifcam.html (Manual VF or English)
Show messages: All  1  2-14
