finding parting lines for mold making in MoI
All  1-3  4-6
10212.4 In reply to 10212.2
> Seems any curves (or surface, or volumes) can make that ... just boolean diff...on any volumes...
> with keeping or not volumes depending of what is wanted...
> here curves
No that's not the same thing. It's not only just cutting a block into 2 pieces anywhere, you need the cut line on the surface to be at the furthest outline from a "pull direction", which is what the Construct > Curve > Silhouette command will calculate.
Once the object is cut along that silhouette then you can construct some surfaces going away from it to divide the block.
10212.5 In reply to 10212.3
Brilliant!
Thanks à lot Michael!
Cool distingo!
Show messages: All  1-3  4-6
