Live Mirror
All  1-3  4-6
10200.4 In reply to 10200.3
I had previously been reading this quite a few times. I was searching quite hard for info. on mirror modeling. Gonna study it really close. I basically like to draw faces. Quadcopters, Airplanes. etc. So when modeling and drawing on one side it sure makes it easy for exact symmetry. I was creating some simple bounding boxes around my drawings. Then subdividing them with added points. Then I was pulling different sets of nodes out to accurate points along the bounding box sides. This is the only way I found to create with equal symmetry. I really appreciate your tips bemfarmer, and Frenchy.
10200.5 In reply to 10200.2
I completely understand what you explained Frenchy Pilou. I had to read it twice and let it soak in three times. he he So stoked when you post these amazing diagrams. Seeing it in action, with your explanations is perfect. Thank you so much.
10200.6 In reply to 10200.3
Thank you bemfarmer. I really appreciate your tips. I was not using the History command at all. That is really helpful. Thanks again.
Show messages: All  1-3  4-6
