zBrush import no faces
All  1  2-6
10198.2 In reply to 10198.1
Hi Guille, does it work better if you set "Output : Quads & Triangles" in the meshing options when you export out from MoI instead of "Output: N-gons" ?
You may also want to set a value for "Divide larger than" to dice things up into smaller pieces like this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
And have you enabled "double faces" in ZBrush ? ;) (i don't remember the exact name)
Seems typic of your result....
EDITED: 2 Mar 2021 by PILOU
10198.4
Under display hit double sided - then if you run DYNAMESH it will unify into a single skin shape.
EDITED: 3 Jul 2022 by ALEXPOLO
10198.5 In reply to 10198.2
Thanks for quick reply, Michael!!!
I'm gonna have to try this out at some point today but looking good, it might need some experimentation.
Just a quick question that you might have answered at some point in the past. Will it be at some point possible to have something similar to zBrush 'Live Booleans' (non-destructive) within MOI or it's not possible at all? just talking from my complete ignorance so correct me if i'm talking non-sense : )
Many thanks!
Guille
10198.6 In reply to 10198.5
Hi Guille, I do want to have editable booleans in the future. It will need a deeper history mechanism which will take a fair amount of work to set up.
Show messages: All  1  2-6
