Dimension in Microns
All  1-11  12-17
10194.12 In reply to 10194.10
In the future I would like to have some method where you could put in a formula to manipulate the dimension's numeric value but MoI does not currently have that function.
Scaling everything is a way you can manipulate the values currently.
10194.13 In reply to 10194.12
Is there any way currently to edit the "master copy" of Details>Object properties>Annotation properties>Text <> to Text <> mu?
So the text of Dimensions would ALL have Text <> mu? Rather than editing each dimension by hand?
10194.14 In reply to 10194.13
Hi Brian, you can select all dimensions and then go to Details... and edit the text value there and it will be applied to all selected objects. You don't need to select them individually.
10194.15 In reply to 10194.14
Thank you Michael.
To mindset, Re: micron:
Did a little google search,
micron = micrometre = micrometer = µm.
micron = 1 X 10power(-6) = .000001 metre = .000001 meters
meter belong to one of the 7 classes of SI units
Just using µ alone means "millionth. (I am unsure of the convention of using µ, rather than µm.
Inserting µ in the Text field is just text to display. It does not "re-program" MoI.
<<Is there any way currently to edit the "master copy" of Details>Object properties>Annotation properties>Text <> to Text <> mu?
I have answered to this question some posts above! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=10194.3
All is done in one pass!
10194.17 In reply to 10194.16
Great tips Pilou! I should have read your post more carefully.
EDITED: 28 Feb 2021 by BEMFARMER
Show messages: All  1-11  12-17
