Is there an OBJ Export script?
All  1  2-7
10190.2 In reply to 10190.1
There is one for the free prog (or Pro) of Subdivision : Rocket 3F
https://rocket3f.com
Here the 2 ShortCuts from Moi to Rocket 3F (will be given in Loading Rocket 3F
Send_to_Rocket_3F hard
Send_to_Rocket_3F Sub
10190.3 In reply to 10190.1
Hi Ed, yes it is possible to do a script that uses predefined meshing parameters. Check out here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1723.10
10190.4 In reply to 10190.3
Perfect Michael - I'll check it out.
10190.5 In reply to 10190.4
Michael -
I got two scripts working based on your forum reference - one for saving a low poly OBJ, and one for saving a high poly OBJ.
However the scripts save every object on the screen. Is there a way to save only the objects I've selected prior to running a script?
10190.6 In reply to 10190.5
Hi Ed, yes you can call moi.geometryDatabase.fileExport() instead of moi.geometryDatabase.saveAs(), it will write only the selected objects out. It takes the same parameters as saveAs().
10190.7 In reply to 10190.6
That works perfectly. This will save a lot of time. Thanks for the awesome support Michael!
Show messages: All  1  2-7
