Data Export Formats Difficults
All  1-3  4-8
10189.4 In reply to 10189.1
Hi Mala, I've sent you back a new version with a couple of tweaks, cutting closed surfaces into 2 parts and redoing 2 trim edges that seemed to be problematic for SAT.
Try exporting that new version to all of SAT/STEP/IGES and see if that works any better.
10189.5 In reply to 10189.4
Hello Michael,
sorry for my delay.
I just converted into the different formats of you refined version and sent it to the manufacturer.
Tommorow I may tell you more...Thank you very much, best regards...
10189.6
cannot find your message in the inbox...so here...the only format the cnc-maker was able to read is the .iges
He has many opportunities to read and translate files...but step sat etc didn“t work.
Not sure whatis his cnc-software exactly...he works with catia, and all the other similar candidates as far as I know.
Ok - seems to work with iges...best regards...
10189.7 In reply to 10189.6
Hi Mala, I'm glad that IGES format worked ok. Over here I tried the STEP and SAT files with 5 different programs and it imported ok into all of them. It would be good to know exactly what programs and what versions they are trying to use and if they aren't trying with more than one program you may want to find another shop.
10189.8 In reply to 10189.7
try to find it out...
Show messages: All  1-3  4-8
