Ctrl, Shift not responding after some time in V4
All  1-2  3-7
10187.3 In reply to 10187.2
Hi Michael, thanks for quick response. Hm yes actually I use a Steelseries keyboard with extra keys and their software for macro commands to have more shortcuts. Think that could be the problem? Interestingly enough it never happened in V3 or V2 with the same setup(this keyboard is more than 5y.o.)
10187.4 In reply to 10187.3
Hi Vitaly,
Possibly - is there a method to disable it and then see if the problem still occurs?
V4 has had a lot of changes to make it cross platform, it uses the Qt framework while v3 and earlier just used plain Windows code.
10187.5
Got it, thanks Michael. I gave it a go on another machine with standard keyboard/no steelseries software and it seems fine. Will try installing new version of the steelseries software see if that helps.
10187.6 In reply to 10187.5
Hi Vitaly, also it looks like there is a factory reset function (may wipe your settings, be careful):
https://support.steelseries.com/hc/en-us/articles/360043313811-My-keyboard-is-experiencing-software-issues
10187.7 In reply to 10187.6
Oh ok! Thank you, let me try!
Show messages: All  1-2  3-7
