Splines from MoI to C4d
All  1-7  8-12
10172.8 In reply to 10172.4
Hi Lara,
For me it works best this way :
If the curves are in one plane (2d curves) I prefer to export them in *.ai format.
If the curves are 3d curves then I go for the *.dxf format.
Choose > polylines from rhe menu. And make sure that your curves are not closed,
they should have two open ends. If you have closed curves, just trim them tp get two
open ends.
10172.9
Hi Tom, I just wanted to post my workflow that was successful...it´s the same like yours. The only difference is that my closed circles arrive cineama with no problems. Thanks...
You can also export artificial surfaces in obj format and kill the internal surfaces in C4D so you obtain only curves 2D/ 3D! :)
10172.11 In reply to 10172.10
good idea. next project. thanks pilou!
Sorry i can't test i have not C4D!
Answer of MacGreggor ;)
the requested format is DXF, with the option Polylines otherwise we have nothing at all in C4D.
The default angle of 1 generates very close points, we can increase this value to 10 for example.
Then in C4D, we get a linear spline, perfectionists fond of precision can use Respline : but 60
https://www.alphapixel.net/respline-c4d/ (scroll)
MacGreggor
So Take Export DXF / Export Type: 3D Curves / PolyLines / Angle 10 :)
Et voila!
By MacGreggor
Modelisation Moi Render VRay
EDITED: 18 Feb 2021 by PILOU
Show messages: All  1-7  8-12
