point import script
All  1  2-6
10165.2 In reply to 10165.1
there is a script that will connect points with a line using a tolerance or "Distance" setting....
This can work in alot of situations, but obviously, in as "Cloud" of points, the human factor cant be scripted.....
If this sounds like something that could help, you can be directed you to the script...
10165.3 In reply to 10165.1
Hi Anthony,
The import window has the options to import the points as Points, Polyline, Control Pts, or Through Pts (interpcurve).
I believe that your points are in order.
Also I very recently made a modified script, ImportPointNetwork script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10134.12
10165.4 In reply to 10165.3
yes the existing point import works. it's just i have to run it twice because you can't keep the points and curve fit them at the same time. i'm hoping there can be an update to it.
i'm afraid i don't understand the script you made. maybe if i try it, it will become clear.
10165.5 In reply to 10165.1
Hi Anthony, I've attached a modified version of the ImportPointFile script which has been restructured to have checkbox options for the different types of entities to build so you can do more than one with a single import.
10165.6 In reply to 10165.5
thanks a lot michael. i'll give this a try today.
Show messages: All  1  2-6
