Newbie Questions
All  1-5  6-11
10164.6 In reply to 10164.4
Hi Anthony so yes the issue is you need to get the rotation pivot point set to a good location.
Using "Reset" on a view will set the rotation pivot point to the center of the selected objects (or to everything regardless of selection if you repeat it a second time).
Another way you can do it is with the Zoom area button on the toolbar at the bottom of a viewport. That will let you pick a point for the center of the zoom window and the point you pick there will become the rotation pivot point so you will rotate around that point.
10164.7 In reply to 10164.6
thanks guys. i have a lot to learn. sometimes i get confused because i go to do something i've done in rhino v5 a thousand times and don't see an equivalent.
one thing i'm noticing that is different is i used to use wireframe view all the time. so i would switch between shaded (like what moi has) and then wireframe (which i can't seem to find in moi).
i was having problems with hiding and showing lines, but i figured it out. moi is quite a bit different than rhino v5. so i probably will have a lot of dumb questions. i did download the pdf help file. so i try to reference that.
10164.8 In reply to 10164.7
""""""so i would switch between shaded (like what moi has) and then wireframe (which i can't seem to find in moi)."""""""""""""
That can be done in MoI's scene browser under types. Use the eye to hide "Faces"... (I think there's a script already written for a shortcut)
But really, that's an old artifact of Rhino's display system not being up to the task on heavier models, so they even made it default to that.
I guess at some point it becomes a "Feature" for some users, expecting it...
MoI can handle those situations "Better" (Opinion).... Best served to look\research, ask about those, than cling to old way...
(Obviously take that with a grain of salt and work how you like. Not a dig on how anybody works it).....
10164.9 In reply to 10164.8
So just having "Show Hidden Lines" turned on in the options-view tab, gets you the same results, without the "Wireframe" view....
10164.10 In reply to 10164.9
yeah. i need to see through the solid better than the hidden line is doing. some surface colors and lighting make it really hard to see through. maybe the scene browser option you mentioned could work. i'll check it out. thanks
thanks burrman. turning off faces did what i needed
EDITED: 14 Feb 2021 by PROP_DESIGN
10164.11 In reply to 10164.7
Hi Anthony, re: wireframe - that's primarily the default view in Rhino be cause Rhino was originally designed to run on a Pentium 90 and it just wasn't possible to work in shaded view all the time.
MoI doesn't really have a wireframe view like that, but you can see wires by turning on hidden line display and also you can hide faces as well.
Just in general MoI is not really designed as a "drop in" replacement for Rhino, it is focused on different things than Rhino.
Show messages: All  1-5  6-11
