How to keep individual cooplanar faces in a Loft (straight/exact)?
All  1-7  8-9
10160.8 In reply to 10160.7
Hi Mauro, yes I do want to make that type of planar face converter in the SubD create menu. I'm not sure exactly when I'll be able to focus on some new SubD stuff yet though.
10160.9 In reply to 10160.6
Pilou -
I made that test using LineWeb.
The issue is, the Loft function combines any coplanar planes into single faces, regardless of what method was used to construct the loft polylines. And that breaks Max's SubD.
Although I think if you export the OBJ, re-import and use Michael's SubD, it works. However as Mauro points out, that's a long back-and-forth process if you're tweaking a design.
Show messages: All  1-7  8-9
