How to keep individual cooplanar faces in a Loft (straight/exact)?
All  1-4  5-9
Message 10160.5 deleted 13 Feb 2021 by PHIRO
LineWeb don't make the job ? (not tested)
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.1
10160.7
Michael:
working on this stuff,can you add a button on SubD menu to convert objects directly with option:more patches-less patches ?
No export and re-import
No go to preferences and select more or less patches
All in a window,istant feedback :)
Ed suggested this on my previous post ;)
M
10160.8 In reply to 10160.7
Hi Mauro, yes I do want to make that type of planar face converter in the SubD create menu. I'm not sure exactly when I'll be able to focus on some new SubD stuff yet though.
10160.9 In reply to 10160.6
Pilou -
I made that test using LineWeb.
The issue is, the Loft function combines any coplanar planes into single faces, regardless of what method was used to construct the loft polylines. And that breaks Max's SubD.
Although I think if you export the OBJ, re-import and use Michael's SubD, it works. However as Mauro points out, that's a long back-and-forth process if you're tweaking a design.
Show messages: All  1-4  5-9
