Node Help
All  1-4  5-8
Maybe something like this ?
10159.6 In reply to 10159.1
Barry,
Brian has already provided you with a universal solution for all point cases.
However when working in 2D on the ground plane, it is not necessary to concern yourself with point rotational data,
hence the Rx, Ry, & Rz outputs need not be connected to ptExt node "angle" inputs, indeed it would suffice to use regular points/point node.
Also Basic/Extract nodes could be used instead of splitPts node, since the only required data outputs are x & y data.
See below
Hope this helps
EDITED: 12 Feb 2021 by JFH
Tricky!
A always find the good Node "color input" to "color Output" is the more difficult when you have not daily practice!
10159.8 In reply to 10159.6
Hi James,
thanks for the explanation.
Barry
Show messages: All  1-4  5-8
