Node Help
All  1  2-8
10159.2 In reply to 10159.1
Make a Rotate after the circle ? ;)
Or maybe better Select a Flat circle as object!
10159.3 In reply to 10159.1
Hi Barry,
Pointarrays have a frame incorporated in their structure.
Posts by Karsten talk about the frames.
Cannot say that I understand them much.
Anyway, Karsten wrote two scripts, splitPts and PointExt which can
be used to change the frame.
Run the output of mPath-Array to pts input of splitPts.
By trial and error:
Outputs of splitPts connect to PointExt as follows:
x-x
y-y
z-z
Rx---no connection
Ry-AngleZ
Rz-AngleX
also connect Rz-AngleY
Point outputs of PointExt node goes to Center of Circle node.
Circle node Out goes to Output.
Maybe try Pilou's rotate on the circle instead?
Is there a node to rotate a frame directly?
10159.4 In reply to 10159.3
your method worked thanks.
I had tried rotating the circle as Pilou suggested but it does not work.
Thanks again.
Barry
Maybe something like this ?
10159.6 In reply to 10159.1
Barry,
Brian has already provided you with a universal solution for all point cases.
However when working in 2D on the ground plane, it is not necessary to concern yourself with point rotational data,
hence the Rx, Ry, & Rz outputs need not be connected to ptExt node "angle" inputs, indeed it would suffice to use regular points/point node.
Also Basic/Extract nodes could be used instead of splitPts node, since the only required data outputs are x & y data.
See below
Hope this helps
EDITED: 12 Feb 2021 by JFH
Tricky!
A always find the good Node "color input" to "color Output" is the more difficult when you have not daily practice!
10159.8 In reply to 10159.6
Hi James,
thanks for the explanation.
Barry
Show messages: All  1  2-8
