Real size grid
 1-6  7-22
10158.7 In reply to 10158.5
Hi Tom,
If you like to work like that you can look at apps designed to help. Maybe better than holding up rulers?
http://www.iconico.com/
10158.8
Hi Tom,
Back when I made jewellery & needed a bezel for oddball shaped stones, I'd take a photo of the stone with a ruler beside it.
I'd take the photo as a "top view" then crop the image to just include the stone & whatever amount of the ruler would fit.
In MoI's top view I'd create a line of 10mm then import image & keep scaling it until 10mm on the ruler matched my 10mm line.
From there on you could create what you needed to without being concerned of dimensions being off.
And remember when first importing your image to click the "Properties" button & tick the "Embed image data in 3DM file".
HTH, Colin
10158.9 In reply to 10158.6
I want to get a visual impression how the (small) object would look in real size.
10158.10 In reply to 10158.8
Thats a great idea, thank you !
10158.11 In reply to 10158.7
Burrmen, this looks awesome. will give it a try now !
10158.12 In reply to 10158.7
Oh, that virtual caliper rocks, great discovery Burrman.
"as far as I know there isn't any way for a program"
Have a look at it, Michael" !
10158.13 In reply to 10158.12
Hi Tom,
It's been a while since i had it loaded.
It has "calibration" of pixels to the units you wanted, but i dont remember that it holds that calibration if you "zoom" the screen. If not, you would have to calibrate every time you reset your screen to some different level.
Putting your known dimension in each view (front, left etc.) You can get pretty quick at a recalibration every time you change viewpoint.
Tell me if it does what you want.
10158.14 In reply to 10158.13
It is perfect for my needs - thank you for that golden tip, Burrman !
As I am currently designing small scale objects with an emphasis on their aesthetical
values, it helps me to evaluate them under their exact size on screen - and such a virtual
Caliper is definitely easier to handle than to hold one against the monitor.
10158.15 In reply to 10158.12
Hi Tom,
I did and it doesn't do that either. It measures pixels and shows inches just by a fixed conversion factor of 96 dpi. On my system here when it says 5 inches it's actually around 4 1/2 inches.
So it doesn't know your physical screen size automatically, but looks like it has a calibration method so you can get it set up for your environment.
10158.16 In reply to 10158.15
You are eight, it is possible to calibrate it.
10158.17 In reply to 10158.16
Hi Tom, also you can calibrate MoI in a similar way like Colin describes above.
Something like - draw a 10 inch line, then zoom until your line matches 10 inches on a ruler and now you're calibrated and any dimensions that you draw will be at real size until you alter the zoom or viewport size.
10158.18
This is similar in concept, but adds some bells and whistles.
It's Free
IC Measure provides powerful tools for the manual measurement of circles, lines, polygons and angles. The convenient user interface enables the easy measurement of lengths, angles and surfaces directly from the image displayed on the monitor. Measurement data can be exported as CSV file.
IC Measure - manual on-screen image measurement and image acquisition
Dimension Images
Load photos from disk.
There is a toolbar tab that says "Microscope", think of it as my "Photo-Rig-Setup's" saved calibration.
10158.19 In reply to 10158.17
Michael, the zoom factor cant be entered manually or even stored, am I right ?
10158.20 In reply to 10158.18
Thats an amazing find - thank you !
10158.21 In reply to 10158.19
Hi Tom, the zoom factor is part of the view definition, it will be saved when you save to a .3dm file and reload.
The zoom factor value for an ortho view does not have a spot in the regular UI for directly editing it but it can be accessed by script.
script: /* display top view zoom factor */ moi.ui.alert( moi.ui.mainWindow.viewpanel.getViewport( 'Top' ).fieldOfViewAngle );
script: /* set top view zoom factor */ moi.ui.mainWindow.viewpanel.getViewport( 'Top' ).fieldOfViewAngle = 30.0;
10158.22 In reply to 10158.21
Thats awesome.
So by entering the desired zoomfactor into the command line of the script I
can always return the "real world" size.
MOI feels like a silken glove - the smoothest workflow ever ;-)
Show messages:  1-6  7-22
