Attach a SYMBOL
 1-5  6-25  26-45  46-50
10155.6 In reply to 10155.3
Hi Mala,
> upload does not work...tried it several times.
There is a limit of 50MB of attachment space per user, to help avoid having the web server get totally filled up. If you have hit this limit you'll need to delete some of your previous attachments before you'll be able to upload more.
You can do that by clicking "Options" on the Top and then "Attachments" on the left side menu.
10155.7 In reply to 10155.1
Hi Mala, those shapes have tight bends in them which will complicate filleting. When you have a bend where the fillet radius is larger than the radius of the bend it will cause the fillet to bunch up on itself like this:
10155.8
The BlendcapScript where do I find it? This is a fine formal concept for a cnc shaped logo...thanks Phiro...
10155.9 In reply to 10155.8
Hi Mala,
Over here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7370.6
You have also the native Construct / Blend, Nsided, NetWork functions for some cases...
Here Blend
Here Nsided (be careful to not take "curves on your selection! Only edges!
Advantage of Nsided : you can SUbDiv at the end! (object on the left! )
EDITED: 10 Feb 2021 by PILOU
10155.11 In reply to 10155.10
Thank you Pilou!
10155.12
Implemented the JS blendcap script.
I tried one time and it worked.
But now, don´t know why, I alway get this message...
P.S.: And the edges are closed.
10155.13
Oh...I took a line...the wrong/doubled one?...now it works.
For the object on the right a little trick is necessary!
Extrude, sSplit, and kill the "door"
10155.15 In reply to 10155.13
About the message !
All these functions use only edges!
So Hide or Erase the "curves" before launch these functions!
About NetWork it's slightly different :)
you must have 2 perimeters and one "Latitude" & one "Longitude" minimum curves at 90° or not at all!!!
free to you after to move the points of the curves as you want...
The curves can be moved till the end of the session! (if object is not modified of course)
Generally not SubDivisible!
Following with any Longitude / Latitude Angles
You can imagine the infinite possibilities! :)
10155.17 In reply to 10155.13
...you go through one thing...next challenges are waiting surely...
BlendCap works. The boolean operation works for the point but not for the 3...hmmm´...why?
10155.18 In reply to 10155.17
Hi Mala,
A couple of different things - one is that your base object is not a solid so you will probably need to use Edit > Trim to cut it instead of booleans. Booleans are based on determining which pieces to keep and which to discard based on what solid volume they are contained inside of. When your base object is not a solid it will have difficulty doing that job.
Then also looking at the underside of your object, it's not good to boolean objects that are barely skimming over the same surface area, for a boolean it's better for objects to push through each other by some amount instead of barely skimming each other:
10155.19 In reply to 10155.17
I believe your 2 objects are false!
Because we can't make a fillet after Boolean Union
I have drawn anything that works as aspected...
So redraw your objects!
PS Michael was more speedy than me! :)
A speedy method with your false objects will be in front view to trim them by a line near their base
Kill the bottom trimed volumes surfaces
(resize if you want in any direction)
Move them to surface start
Now all can work as aspected with the Flow method
Boolean result on the curvated target surface
Make the Fillets if necessary
EDITED: 11 Feb 2021 by PILOU
10155.21
10155.22
This is not the intention...
That´s the middle and ring finger of a hand. But I need a blendcap and the fingers are still two fingers...
How can I do this goal?
10155.23
I also tried a concept with two splines. They are closed splines. BlendCap says: I do need closed splines to do the job.
10155.24 In reply to 10155.22
Hi Mala, you can put a fillet there as long as it's not overabout 0.17 radius:
If you need something that is kind of blobby and smooth to an irregular outline you may be better off building something like that with a Sub-D modeling program rather than a CAD program.
10155.25 In reply to 10155.23
split finger curves in two then blend.
Barry
Show messages:  1-5  6-25  26-45  46-50
