Attach a SYMBOL
 1-6  7-26  27-46  47-50
10155.27 In reply to 10155.25
Barry-H, could you show the steps to achieve that? I can't figure out what you are blending with what exactly
10155.28 In reply to 10155.27
Maybe like this ;) Blend is a magic function!
1- 4 --> 3 Blend
2 - 3 Blend
will give also another different valid result
4 - 2 Blend ->3
1 - 3 Blend
etc...
Order is important following result wanted!
EDITED: 12 Feb 2021 by PILOU
10155.29 In reply to 10155.27
Hi DanC,
the finger shapes are extruded then the top edge of each finger are trimmed at the tips.
You can then blend one side of the finger to the other.
Hope this helps.
Barry
10155.30
Ah, thank you both. So yes, more trims. I thought there was only one trim (at the visible split in the top surface), but you need one more. I was trying to cap a similar shape extrusion with these kind of concave parts to the shape and couldn't find an elegant solution as the BlendCap function is only successful with concave profiles to a certain degree. When you have something like this with the 'fingers' it just doesn't know what to do.
10155.31
My Internet is down...so communication with cell phone...
I cannot solve it. I tried all your concepts. No success. If I split the two fingers, blendcap needs a closed spline. Which I normally have. The objekt info tells me so. But always this no-go message...hmmm'...
10155.32
Pilou, can't follow your workflow...
EDITED: 13 Feb 2021 by MALA
10155.33 In reply to 10155.32
That you maybe missed on the video is the line who "Trim" the perimeter...for have the 3 curves segments (1 2 4)
EDITED: 13 Feb 2021 by PILOU
10155.34 In reply to 10155.33
I do not understand trim the perimeter and how to do that.
10155.35 In reply to 10155.34
Like this you trim the top perimeter edge!
(carreful to kill a possible curve against the perimeter edge! )
Kill of course the line after the trimming...if necessary
PS the vertical line is the Curve generator (made during the extrude ) so automatic trimming! :)
You can now make your Blends!
EDITED: 14 Feb 2021 by PILOU
10155.36
And now the splines are splitted And blendcap needs closed lines...hmmm'...
10155.37
10155.38 In reply to 10155.37
Hi Lara,
Use blend NOT blend cap.
Barry
10155.39
Pilou, do you use the "blendcap" option pressing tab before?
10155.40 In reply to 10155.39
No i use only Blend! ;)
10155.41
It worked once. To check the workflow. Result was not good, so I tried from beginning. Result: no result or successful blend operation.
Here is my workflow:
1. Only the two fingers spline as base
2. Extrusion
3. Eleminate the spline on top/additionally? generated spline
4. Generate a simple spline through snapping points of the finger spline - trim of the two splines
5. Activate one part of the splitted fingerspline
6. Do blend
7. No operation is done
8. hmmm'...
10155.42 In reply to 10155.41
Lara,
split finger edges using the trim tool then blend as shown in photo.
Barry
Schema & Animation that i made shows the same Barry Method! :)
10155.44 In reply to 10155.42
...o.k....this is not true...thank you for your patience!
10155.45 In reply to 10155.44
Are all curves hidden before Blend of Edges?
-Brian
10155.46 In reply to 10155.45
As you want (kill or hide) : essential is not select them for a Blend Surface(s)!
An easy way is use the Browser for disable curves! :)
Show messages:  1-6  7-26  27-46  47-50
