Attach a SYMBOL
 1-19  20-39  40-50
A speedy method with your false objects will be in front view to trim them by a line near their base
Kill the bottom trimed volumes surfaces
(resize if you want in any direction)
Move them to surface start
Now all can work as aspected with the Flow method
Boolean result on the curvated target surface
Make the Fillets if necessary
EDITED: 11 Feb 2021 by PILOU
10155.21
10155.22
This is not the intention...
That´s the middle and ring finger of a hand. But I need a blendcap and the fingers are still two fingers...
How can I do this goal?
10155.23
I also tried a concept with two splines. They are closed splines. BlendCap says: I do need closed splines to do the job.
10155.24 In reply to 10155.22
Hi Mala, you can put a fillet there as long as it's not overabout 0.17 radius:
If you need something that is kind of blobby and smooth to an irregular outline you may be better off building something like that with a Sub-D modeling program rather than a CAD program.
10155.25 In reply to 10155.23
split finger curves in two then blend.
Barry
For Blend something for have a surface(s) you must have yet some surface(s) to the curves selected!
10155.27 In reply to 10155.25
Barry-H, could you show the steps to achieve that? I can't figure out what you are blending with what exactly
10155.28 In reply to 10155.27
Maybe like this ;) Blend is a magic function!
1- 4 --> 3 Blend
2 - 3 Blend
will give also another different valid result
4 - 2 Blend ->3
1 - 3 Blend
etc...
Order is important following result wanted!
EDITED: 12 Feb 2021 by PILOU
10155.29 In reply to 10155.27
Hi DanC,
the finger shapes are extruded then the top edge of each finger are trimmed at the tips.
You can then blend one side of the finger to the other.
Hope this helps.
Barry
10155.30
Ah, thank you both. So yes, more trims. I thought there was only one trim (at the visible split in the top surface), but you need one more. I was trying to cap a similar shape extrusion with these kind of concave parts to the shape and couldn't find an elegant solution as the BlendCap function is only successful with concave profiles to a certain degree. When you have something like this with the 'fingers' it just doesn't know what to do.
10155.31
My Internet is down...so communication with cell phone...
I cannot solve it. I tried all your concepts. No success. If I split the two fingers, blendcap needs a closed spline. Which I normally have. The objekt info tells me so. But always this no-go message...hmmm'...
10155.32
Pilou, can't follow your workflow...
EDITED: 13 Feb 2021 by MALA
10155.33 In reply to 10155.32
That you maybe missed on the video is the line who "Trim" the perimeter...for have the 3 curves segments (1 2 4)
EDITED: 13 Feb 2021 by PILOU
10155.34 In reply to 10155.33
I do not understand trim the perimeter and how to do that.
10155.35 In reply to 10155.34
Like this you trim the top perimeter edge!
(carreful to kill a possible curve against the perimeter edge! )
Kill of course the line after the trimming...if necessary
PS the vertical line is the Curve generator (made during the extrude ) so automatic trimming! :)
You can now make your Blends!
EDITED: 14 Feb 2021 by PILOU
10155.36
And now the splines are splitted And blendcap needs closed lines...hmmm'...
10155.37
10155.38 In reply to 10155.37
Hi Lara,
Use blend NOT blend cap.
Barry
10155.39
Pilou, do you use the "blendcap" option pressing tab before?
Show messages:  1-19  20-39  40-50
