Attach a SYMBOL
 1-12  13-32  33-50
10155.13
Oh...I took a line...the wrong/doubled one?...now it works.
For the object on the right a little trick is necessary!
Extrude, sSplit, and kill the "door"
10155.15 In reply to 10155.13
About the message !
All these functions use only edges!
So Hide or Erase the "curves" before launch these functions!
About NetWork it's slightly different :)
you must have 2 perimeters and one "Latitude" & one "Longitude" minimum curves at 90° or not at all!!!
free to you after to move the points of the curves as you want...
The curves can be moved till the end of the session! (if object is not modified of course)
Generally not SubDivisible!
Following with any Longitude / Latitude Angles
You can imagine the infinite possibilities! :)
EDITED: 10 Feb 2021 by PILOU
10155.17 In reply to 10155.13
...you go through one thing...next challenges are waiting surely...
BlendCap works. The boolean operation works for the point but not for the 3...hmmm´...why?
10155.18 In reply to 10155.17
Hi Mala,
A couple of different things - one is that your base object is not a solid so you will probably need to use Edit > Trim to cut it instead of booleans. Booleans are based on determining which pieces to keep and which to discard based on what solid volume they are contained inside of. When your base object is not a solid it will have difficulty doing that job.
Then also looking at the underside of your object, it's not good to boolean objects that are barely skimming over the same surface area, for a boolean it's better for objects to push through each other by some amount instead of barely skimming each other:
10155.19 In reply to 10155.17
I believe your 2 objects are false!
Because we can't make a fillet after Boolean Union
I have drawn anything that works as aspected...
So redraw your objects!
PS Michael was more speedy than me! :)
A speedy method with your false objects will be in front view to trim them by a line near their base
Kill the bottom trimed volumes surfaces
(resize if you want in any direction)
Move them to surface start
Now all can work as aspected with the Flow method
Boolean result on the curvated target surface
Make the Fillets if necessary
EDITED: 11 Feb 2021 by PILOU
10155.21
10155.22
This is not the intention...
That´s the middle and ring finger of a hand. But I need a blendcap and the fingers are still two fingers...
How can I do this goal?
10155.23
I also tried a concept with two splines. They are closed splines. BlendCap says: I do need closed splines to do the job.
10155.24 In reply to 10155.22
Hi Mala, you can put a fillet there as long as it's not overabout 0.17 radius:
If you need something that is kind of blobby and smooth to an irregular outline you may be better off building something like that with a Sub-D modeling program rather than a CAD program.
10155.25 In reply to 10155.23
split finger curves in two then blend.
Barry
For Blend something for have a surface(s) you must have yet some surface(s) to the curves selected!
10155.27 In reply to 10155.25
Barry-H, could you show the steps to achieve that? I can't figure out what you are blending with what exactly
10155.28 In reply to 10155.27
Maybe like this ;) Blend is a magic function!
1- 4 --> 3 Blend
2 - 3 Blend
will give also another different valid result
4 - 2 Blend ->3
1 - 3 Blend
etc...
Order is important following result wanted!
EDITED: 12 Feb 2021 by PILOU
10155.29 In reply to 10155.27
Hi DanC,
the finger shapes are extruded then the top edge of each finger are trimmed at the tips.
You can then blend one side of the finger to the other.
Hope this helps.
Barry
10155.30
Ah, thank you both. So yes, more trims. I thought there was only one trim (at the visible split in the top surface), but you need one more. I was trying to cap a similar shape extrusion with these kind of concave parts to the shape and couldn't find an elegant solution as the BlendCap function is only successful with concave profiles to a certain degree. When you have something like this with the 'fingers' it just doesn't know what to do.
10155.31
My Internet is down...so communication with cell phone...
I cannot solve it. I tried all your concepts. No success. If I split the two fingers, blendcap needs a closed spline. Which I normally have. The objekt info tells me so. But always this no-go message...hmmm'...
10155.32
Pilou, can't follow your workflow...
EDITED: 13 Feb 2021 by MALA
Show messages:  1-12  13-32  33-50
