Moi's approach is a little bit strange to other 3D software
All  1-6  7-13
10154.7 In reply to 10154.6
it's for that saving "Project 1", 2, 3,...can be a very cool method for artificial history! ;)
More speedy than modify directly a complex object!
10154.8 In reply to 10154.4
Thanks to Michael, he discussed this many times on the forum, so I easily remembered it, the last time it was recently.
The place indicated by the arrow has problems, it is still unclear.
I checked again everything is fine apparently I did it sloppily the first time;)
EDITED: 10 Feb 2021 by WN
Size: 291.5 KB, Downloaded: 25 times, Dimensions: 1149x872px
Size: 186.5 KB, Downloaded: 18 times, Dimensions: 1190x472px
Size: 265.9 KB, Downloaded: 23 times, Dimensions: 1301x703px
Size: 323.2 KB, Downloaded: 24 times, Dimensions: 1501x769px
Size: 171.6 KB, Downloaded: 29 times, Dimensions: 1083x808px
10154.9 In reply to 10154.8
In Moi when you make a general Fillet max Angle fillet is the maximum allowed along the general path!
(even other places along the path can accept it)
So make it and then apply a "Variable fillet" with more angle at the possible places!
In fact here no need to trim the volume! Just make your Variable fillet as you want! :)
Here maxi will be locally the right height of the object on some places!
You can put variable angle at the Vertex (here) And / Or along the path ! (not shown here)
(You can put any number of new Points on a Point Set and any number of New Point Set )
EDITED: 10 Feb 2021 by PILOU
10154.10
Here's another option ...
Size: 240.6 KB, Downloaded: 26 times, Dimensions: 1278x949px
Size: 264.6 KB, Downloaded: 21 times, Dimensions: 1305x950px
Size: 255.2 KB, Downloaded: 20 times, Dimensions: 1316x936px
Size: 161.2 KB, Downloaded: 26 times, Dimensions: 1036x745px
10154.11 In reply to 10154.9
Frenchy Pilou, thank you!
10154.12 In reply to 10154.1
Hi Jack, the filleter in the geometry library that MoI uses does not like it if you have planes fragmented into separate faces. If you clean up the model so that coplanar areas are made up of just one large plane instead of multiple fragments then it should work.
So for your case here the easiest way to do it is to select these faces:
Delete them:
Also do the same to these ones on the bottom:
Then select the whole object and run Construct > Planar - that will fill in planar holes with one large trimmed plane and join them in.
After that you can then fillet that edge ok:
Simple!
Show messages: All  1-6  7-13
