MoI V4 Window 10 : This app might harm your device message
10151.1
Hi
I just download V4 in order to try but get Window warning message as attached)
Not sure if it safe to install. Just ask before installing it
Thank you.
Size: 49.5 KB, Downloaded: 19 times, Dimensions: 582x453px
Size: 46.4 KB, Downloaded: 15 times, Dimensions: 786x712px
10151.2 In reply to 10151.1
Hi Kwin, it's called a "false positive" - it's a mistake by the anti-virus checker mis-identifying the MoI trial version as a virus.
It's probably because the trial version uses a system called "WinLicense" that makes it more difficult for hackers to remove the trial time limit.
You should override it and allow it to install normally. If you need further reassurance you can put in the trial address:
http://moi3d.com/4.0/trial/moi_v4_trial_setup.exe
into the URL option at https://www.virustotal.com which checks it with something like 40 different anti-virus engines, none of which flag it as having any virus in it.
10151.3 In reply to 10151.2
Hi Michael Thank you very much for your quick reply. I already ignore Window warning message and successfully install Moi trail version. :)
