how to cut on cylinder surface
All  1-8  9-11
There is another one very speedy but... :)
The Flow Function
10148.10 In reply to 10148.9
"... thx, but not a speedy way."
Just to be clear, you changed your images after I replied. I was responding to the vertical slot and using boolean diff to create it.
If performing a simple boolean operation is not speedy enough, then I don't know what is.
To address your latest images:
I would have created the cylinder in MoI with the horizontal groove in a single operation using Revolve with a profile curve that included a notch for the groove.
Then create each vertical groove by extruding a rectangle and Boolean Diff with the cylinder.
Practice will make very speedy.
10148.11 In reply to 10148.10
I think this caused by misunderstanding, but thank you sincerely.
I tried all method in this thread, use "Shell" fit my purpose.
Show messages: All  1-8  9-11
