FILL AREA WITH OBJECTS EQUALLY SPACED
All  1-2  3-11
10147.3 In reply to 10147.1
Hi Alex, you might find some ideas on this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10052.1
Probably the best bet is using a Grasshopper component for Rhino:
https://www.grasshopper3d.com/video/circle-packing
Re-arranging to hex grid. Drawing a few hexagons helps with manipulation.
Scale circles. Move to fit+/-.
ScaleIndividual Script to shrink the circles back to size.
CenterPoint script is helpful.
Better, but not done.
Could repeat...
Edit, Deleted atachment.
Google search of "Locomotive steam boiler", images, show hex "D" layout.
EDITED: 11 Feb 2021 by BEMFARMER
10147.5
Hi Brian and Michael,
Thanks for the input and advice I am modelling a flange for a heat exchange unit and came up with this as a manual solution.
A series of semi circle arcs which I used unwrap curve. Worked out the length of each curve and used array over curve once I knew how many per curve. Gave a good enough result not perfect but should disperse heat even enough. Will explore Circle Packing in Rhino but was on tight time frame on this one so sometimes time spent learning new tricks versus getting the knuckles dirty and knocking it out.
10147.6 In reply to 10147.5
Hi Alex.
Your solution looks excellent.
Maybe a fibonanacci layout would work?
-Brian
Scatter tools, dispersion ...? by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
10147.8 In reply to 10147.1
Hi Alex,
I have created a basic spacing nod file on the Nodeeditor that can set minimum gaps.
The dimensions that can be adjusted are shown on the photo.
The number of arcs are 12 but if you need more let me know.
Anyway hope this helps.
Barry
Edit:
Nodeeditor added.
EDITED: 18 Feb 2021 by BARRY-H
10147.9
Hi Barry,
Many thanks for taking time in putting this together looks great - I have a large collection of your scripts and your input is gold.
I am having trouble running the node am I missing some components?
Alex.
10147.10 In reply to 10147.9
Hi Alex,
I have updated my previous post adding the Nodeeditor I used plus a modification
to the nod file collating the outputs into one so you can see the total number of circles.
Barry
10147.11
Hi Barry,
Thanks again for your input looks great and working for me now - Will add to my collection of BARRY SCRIPTS your insight is well appreciated - my NODE skills are basic and looking at your MACRO section makes my head spin :) your contributions to the MOI community highlight how such an agile tool can be used to solve high end problems.
Keep powering on
Alex.
Show messages: All  1-2  3-11
