Crease
 1-8  9-28  29-38
10132.29 In reply to 10132.28
Hi Mala,
> Like you may see the crease is at the place where it belongs. But not outside and not rotated.
> How do I fix that?
You need to apply the rotation to the base object in relation to the base plane, not try to do it by rotating a trimmed area.
See these previous posts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10132.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=10132.18
The Flow function don't make the absolutly perimeter filling of the projected perimeter rotated started form!
So a little trick is necessary :)
Move the result of the Flow result and make a new "projection" !
(trim the tube, kill the curve perimeter, move the surface on the hole )
Join all and you will have a perfect new solid with a perfect jointure!
EDITED: 8 Feb 2021 by PILOU
10132.31
this is my result of michaels workflow.
I rotated the loft. Now it is placed rotated. But it does not fit.
I do not know if this depends on the point where I do click the base plane in the flow-workflow.
I cannnot take the middle point of the oval base plane. Clicking on it, I select the oval loft.
Pilou - yours I try now too. But I not really look through this concept and how to do...ok...let´s see...
EDITED: 10 Feb 2021 by MALA
10132.32 In reply to 10132.30
hi, Pilou,
is this how you mean? (i´m irritated of the step where it looks like an extrusion...)
I took the loft, projected onto the ring...but now...how to make the flow without the baseplane of the oval? Creating one is nothing I can see in your workflow...
10132.33 In reply to 10132.32
The crease surface not rotated has always base who is the exact perimeter of the surface to projected! ;)
else the Flow can't be executed!
And it was yet deformed by the first and unic Flow! (on the left)
Another general trick (Function ShrinkTrimmedSrf for limited Point to surface)
When you rotate something here the surface of crease and want to modify with the Edit Show Point for better form
the grid of point is rotated!
so the trick is to use the CPlane!
Another thing : when you modify something by moving point
the perimeter don't stat horizontal!
So just trim it by a line for can make a plane for fill the hole!
10132.35 In reply to 10132.34
Sorry Pilou - this confuses me fully...can´t follow you...
10132.36 In reply to 10132.35
You are more speedy than me : no time to put the video :)
now that is one.. so return previous post :)
10132.37 In reply to 10132.36
speedy is not the correct compliment I guess.
But I think I got the workflow of Michael checked. Now finetuning.
Pilou...I hope to look behind your concept of placing the crease exactly.
10132.38 In reply to 10132.37
If you see my little video surface on the right is obligatory well placed anywhere you want! (on the same horizontal of the tube) ;)
Show messages:  1-8  9-28  29-38
