v1 beta - axis snap + IGES (old thread)
 1-16  17-34
1013.17 In reply to 1013.16
while playing with the axis snap i noticed what i percive to be a general snap problem; if you are drawing or making a construction line starting along the major x or y axis lines, you can not snap to any other grid point directly in the x or y direction??
1013.18 In reply to 1013.16
Hi Paul, thanks for the feedback.
> Maybe a filter on the input boxes to reject any kind of keystrokes other than numerals would work better?
There is actually a filter in place already. But there are a few keys other than numbers that are valid to type into that point coordinate box: R, @, < , W .
R and @ are used for relative point entry, < for entering an angle constraint, and W for world polar coordinates.
Did you happen to be using one of those keys? Other keys should work, for instance here I set up "K" for keeping construction lines and I don't have any problem triggering it while inside the line command for example.
1013.19 In reply to 1013.18
Yep, that was it :) I assigned the shortcut key to W. (Slaps self in head, looks around sheepishly...)
Paul
1013.20 In reply to 1013.17
Hi xrok1 - yes good call that one is going to be a problem.
Object snaps have priority and if one of them is activated then grid snap will not kick in.
At the moment you can work around it by disabling Object Snap temporarily which will then let the grid snaps come through.
But this definitely needs to be fixed.
I think what makes sense is if there is an "on" snap (axis is kind of a variety of "on"), and the object snapped on to is a line running coincident with a grid line, I'll take a look and see if there is a grid intersection close by and redirect to that.
Other than that issue, what do you think of the new axis snap - worthwhile or does it get in the way?
I wouldn't normally be messing with a major new feature like this right before release, but it just seems like this can replace a lot of basic construction line creation, which is especially good for beginners since they don't even know about construction lines.
Thanks for your attention to the details here!
1013.21 In reply to 1013.19
Hi Paul - well the W is a pretty obscure thing - it's just for polar coordinates centered at the origin instead of from the previous point, like w5<24 .
I was just thinking that I could pretty easily remove the auto-focusing for W because that world polar coordinate entry is just not going to be used very often, and it would still work if you clicked on that control first.
However in V2 when there is an option to relocate the construction plane to some other location, it will probably work well to use regular points to be in that relocated coordinate system, and have w as a prefix for entering world coordinates.
So I guess I will leave it so it can be leveraged in the future.
1013.22 In reply to 1013.20
thumbs up! i like it. Another small attention to detail that sets your software apart, and shows that you are a user of this software, not just a developer trying to push a product.
1013.23 In reply to 1013.21
I knew about the R and < , the W just kind of slipped by me--
Just ignore me when I start babbling !
Paul
I've put up a new patch here: (EDIT: Oct/21/2008 removed old broken link - this was an old patch for a v1 beta, it has already been incorporated into the v1 release and all v2 betas).
To install it unzip it and copy the moi_lib.dll file over top of the old version in C:\Program Files\MoI beta Sep-4-2007\ .
You can now hold down Alt when clicking to temporarily turn off snapping.
Fixed the new axis snap so it co-exists with grid snap instead of overriding grid snap.
Fixed some bugs and improved triangulation to help generate fewer skinny triangles, when exporting using "Quads & Triangles" or "Triangles only" settings.
EDITED: 21 Oct 2008 by MICHAEL GIBSON
Works fine :)
1013.26
WOW! Awesome! :)
1013.27
thanks!
Thread Split: This post has been moved here
1013.29
>>> I've put up a new patch here: http://moi3d.com/beta/Sep4_patch3.zip
Error 404 :( anyone else getting this ?
1013.30 In reply to 1013.29
same but i believe that is include in the 21 Sep beta ;)
1013.31 In reply to 1013.29
Hi Danny,
This is an old thread concerning MoI beta version 1 (one).
1013.32 In reply to 1013.29
Hi DannyT,
Error 404
Yes i have the same problem
1013.33 In reply to 1013.32
Like Steve mentioned, that file was an old one for a v1 beta, the stuff in it has already been included in the final v1 release and also all v2 betas.
1013.34
What the !!! Lol, I thought it was a patch for the current beta, all I noticed was 'sep' and didn't check the thread date, doh!
thanks guys
Show messages:  1-16  17-34
