Sweep beginners question
All  1-2  3-11
10126.3 In reply to 10126.2
ok. I have tried this before, but didn`t get the desired result so i went for simplification path trying to do one half first and then merge it with the other half.
here is my file. Ok. cant attach here, so I will try at my first post.
Your example looks so effortless, but which is the shape and what are the rails?
10126.4 In reply to 10126.3
Network don't need rails : all are just cuves in any order!
better if they snap on their path
That makes a surface
Here the Planar sides (of course just draw a vertical segment before the "Planar" ) close the volume: so just "Join" all or "Boolean Union" for obtain a "Solid"
EDITED: 31 Jan 2021 by PILOU
10126.5 In reply to 10126.4
ah, i see different tool, I will try this thank you very much!
10126.6 In reply to 10126.5
Seems You have no problem with this Faw nose ?
10126.7 In reply to 10126.6
sorry wrong file
heres the problemfile
10126.8 In reply to 10126.7
I redraw your curves...as you can see all curves are "trimed" for each "patch"
All are "snaped" each other
10126.9 In reply to 10126.8
Thats what I want to achieve. though there is some strange irragularity on the right side ahh thats from my doubled spline probably
I will try to replicate it tomorrow with the network toll...Thanks a lot!
10126.10 In reply to 10126.9
Jake –
You can also experiment using Loft to make this nose cone.
I arranged your curves as below. First, I ran the “Rebuild” command to lower and simplify the point count.
Next I trimmed the base into two parts, orange and red. The two curves must meet at a single point.
Next I made the blue profile curve as a single curve. The ends must touch the base curves where they meet.
The only tricky part to this Loft arrangement is how you pick the curves:
• Select the red and orange base curves simultaneously (not one at a time). *
• Select the blue profile curve.
• Loft using Normal / Auto settings.
* An alternate way to select the curves is to select all 3 at once, deselect the blue curve, then re-select the blue curve.
EDITED: 31 Jan 2021 by EDDYF
10126.11 In reply to 10126.1
Hi jake, so for original question on why sweep is not working well there - the way one rail sweep works is it moves the profile along the rail rotating it by the rail curve's tangent direction. You can get a kind of preview of what that is doing if you use Transform > Array > Curve on your profile, which will generate this:
So notice there how the sections are bunching up and crossing over each other there? That's what is making a poor quality surface result.
For one-rail sweep it's kind of a tube-like construction mechanism where you can't have a profile curve go off by a larger distance than the radius of the bend, otherwise sections will bunch up as shown above.
Instead of the profile curve rotating with the curve tangent, you would instead need it to pivot around its own endpoints. I want to make that kind of pivot an option for sweep in the future but there is a fairly similar command now called rail revolve, under Construct > Revolve. It allows for one profile curve, one rail curve and then also a revolve axis. The profile will pivot around the revolve axis while scaling out to meet the rail. So since it has a pivoting action it could work for this kind of case.
Anyway hope that helps explain what you were running into originally.
Show messages: All  1-2  3-11
