Moving Seam of closed curve
All  1-3  4-18
10125.4 In reply to 10125.3
Hi Wayne,
allocated the script to a key (Add curve.changeClosedCurveSeam( new_start_parameter, rebuild_circles /*optional, default = true */ ); )
but could not get it to work.
Any ideas
Barry
With the first image of the thread : does we redraw something (loft, revolve, sweep) with the new section , or it's directly modifyed ?
10125.6 In reply to 10125.5
the first image shows how the curves where constructed and when joined the resulting sweep with all the seams.
The second image is the joined curve that as the rebuild command applied and only one seam which position you cannot control.
the third shows the rebuilt curve split where you want seams to be then joined and when swept give 2 seams.
The fourth shows the third curve with 1 seam point removed.
Hope this helps
Barry
10125.7 In reply to 10125.6
Ok!
In what these over numerous seams are ennoyous ?
Seems render engines pass over them ...
10125.8 In reply to 10125.4
Hi Barry,
That's not a complete script, it's one fragment that needs a location for the new seam point.
I've attached a plug-in command that lets you pick a point and then calls that function to modify the seam to that point.
EDIT: 2/1/2021 - fixed bug with clicking on clines or axis lines or on intersections between a curve and a cline/axis line.
EDITED: 1 Feb 2021 by MICHAEL GIBSON
10125.9 In reply to 10125.8
thank you works a treat.
Barry
10125.10 In reply to 10125.7
being able to move the seam is not to improve render.
An example of a problem and how being able to move the seam helps is shown in the photo.
Barry
10125.11 In reply to 10125.10
@ Barry
Indeed! Many thanks for the enlighting example!
Made the French ChangeClosedCurveSeam (V4) here with the English so Done & Cancel :)
but seems there is a BUG, not for the action itself but for selection another one...
(MarkCurveStart for control result - ChangeClosedCurveSeam)
EDITED: 1 Feb 2021 by PILOU
10125.13
this script will be usefull !
draw rectangle -> fillet, run script
same results : on corner throw error, on curved nothing happends
- Tudor -
Yes, strange problem...
I had the same problem as Pilou, but after more tests I can't reproduct the problem...
Another strange reaction is, on a non soft curve (with hard points) the script add a new hard point.
Exemple :
I do a rectangle.
I add filet on the angles.
If I use the script it adds a new hard point.
If I reuse the script it adds a second new hard point.
But If I do a rectangle, filet it and use the reconstructCurve plugin, next each time I use ChangeClosedCurveSeam, the seam is moved (not added).
EDITED: 1 Feb 2021 by PHIRO
10125.15 In reply to 10125.13
Hi Tudor,
The script is for use with closed curve with one seam.
Your example needs the rebuild command first thus reducing it to a one seam curve.
Barry
10125.16 In reply to 10125.12
I can replicate your error by activating the construction line to position the seam point.
Did you do this ?
Barry
10125.17 In reply to 10125.16
Something like move the new point clicked to the old one and reclick...
and repeatable...at each time that bug (i repeat the function by Right Click)
10125.18 In reply to 10125.12
The bug was if you clicked on a construction line or axis line or at an intersection snap between a curve and a construction line or axis line.
I've updated the attachment above with a fixed version.
Show messages: All  1-3  4-18
