Moving Seam of closed curve
All  1-13  14-18
Yes, strange problem...
I had the same problem as Pilou, but after more tests I can't reproduct the problem...
Another strange reaction is, on a non soft curve (with hard points) the script add a new hard point.
Exemple :
I do a rectangle.
I add filet on the angles.
If I use the script it adds a new hard point.
If I reuse the script it adds a second new hard point.
But If I do a rectangle, filet it and use the reconstructCurve plugin, next each time I use ChangeClosedCurveSeam, the seam is moved (not added).
EDITED: 1 Feb 2021 by PHIRO
10125.15 In reply to 10125.13
Hi Tudor,
The script is for use with closed curve with one seam.
Your example needs the rebuild command first thus reducing it to a one seam curve.
Barry
10125.16 In reply to 10125.12
I can replicate your error by activating the construction line to position the seam point.
Did you do this ?
Barry
10125.17 In reply to 10125.16
Something like move the new point clicked to the old one and reclick...
and repeatable...at each time that bug (i repeat the function by Right Click)
EDITED: 1 Feb 2021 by PILOU
10125.18 In reply to 10125.12
The bug was if you clicked on a construction line or axis line or at an intersection snap between a curve and a construction line or axis line.
I've updated the attachment above with a fixed version.
Show messages: All  1-13  14-18
