Request for help measure and polygon
All  1-9  10-13
10124.10 In reply to 10124.7
Kai, what language do you use in your program?
Do you have any problems using measurement tools?
I do not understand what the sizes 33,6 and 31,45 correspond to in the screenshot, if it is difficult for you to explain, attach your model file to your message.
If you left-click on some tool icon and then press F1, the program will show help for this tool.
10124.11 In reply to 10124.6
to get to a distance constraint in the polygon tool, i have to actually click the field i want?
I cant tab to it.
Is this the way it's always been? I cant get into the coordinate or other fields without clicking..
10124.12 In reply to 10124.11
Hi Burr, yes that's correct it's always been that way. It's a kind of special case because the polygon command has an input field for number of sides and that's where keyboard focus will go if you start typing.
It's on my list to investigate some kind of Tab key combination that will put keyboard focus into the XYZ control always maybe something like Shift+Tab, or Ctrl+Tab. Or maybe the polygon command should have a radius value field so you don't need to use distance constraint.
10124.13 In reply to 10124.12
Just checking. I can click the distance field. I would use it when in the point to point of the polygon edge function, as opposed to center out...
I just thought it was different, but realize it's not...
Show messages: All  1-9  10-13
