export issue between Rhino 7 and Moi 4
All  1-2  3
10123.3 In reply to 10123.1
Hi moka,
> before the previous release of Rhino and Moi, we would share between the two programs simply by copy+paste.
The support is the same in MoI v4 as it was in Moi v3, the change is in Rhino v7 which no longer supports the Rhino v5 clipboard format.
> I noticed however that in the new version of moi , when I copy objects from Rhino 7 into moi 4, the objects
> are placed incorrectly in relation to one another.
> It seems to be random as well. Meaning that, in the example that i am attaching, if I were
> to add another shape, such as a square, that one might be too small, or too big, or placed at the wrong location.
i believe this is because it's ending up using PDF format for the transfer, and it's probably making a projection based on the active view in Rhino when you do the Ctrl+C there.
See the link above that Brian posted for a utility program that you can set up to enable 3DM copy/paste between Rhino v7 and MoI.
> Also, in general, do you have plans to support opening Rhino7 files in moi?
I'm not sure, maybe someday. I'm not really a fan of the way Rhino breaks file compatibility to older versions with every release.
Show messages: All  1-2  3
