STUMPED: tapered oval spoke
 1  2-21  22-23
Maybe you can make one by one
Then Boolean
Then Fillet the intersections
Here the first :)
EDITED: 21 Jan 2021 by PILOU
10121.3 In reply to 10121.1
Hi twofoot,
In my opinion,
The two shapes pointed to are "Hubs", ("Rings"), for which each profile shown needs to be Revolved about the center point of the wheel.
The "spokes" are shown by the two angled, mostly straignt, curves, between the two Rings.
Their cross sections need to be shown.
Also, a view from the side of the wheel should be uploaded. It looks like there is such a view off to the left of your uploaded image.
Also, need to see the portion of the page below the uploaded image...
- Brian.
If the "spoke" is mostly solid, it may also need to be a Revolved solid, perhaps with pie sections cut away, per side view...
A google of "Train wheels images" shows different types of wheels. Perhaps you could upload an image of the corresponding type.
EDITED: 21 Jan 2021 by BEMFARMER
10121.4 In reply to 10121.1
Hi twofoot,
Please post .3dm.
It is hard to understand what you are asking for...
10121.5 In reply to 10121.1
Hi Chris, yes if you have a side or any other view image and if you could post the .3dm file with your current results in it that would help a lot to better understand what you're trying to do.
10121.6 In reply to 10121.1
Hi Chris,
Is this the front truck wheels for a railroad train and tender? 999? In the Museum of Science and Industry, Chicago, IL ?
Wayne
https://www.albanyinstitute.org/tl_files/collection/historical-objects/1999.29_nycr-999.jpg
EDITED: 22 Jan 2021 by WAYNEHILL5202
There are a few other photos of this train.
The spokes appear to be a tapered, rounded, rectangular shape, wider from the center of the track to the outside of the track.
There would be some fillets as well.
Outside view would help establish their other dimensions seen from the side, and perhaps some of the fillets.
The inner and outer hubs, and the (10?) spokes, were likely cast in one piece.
I think that the outer rim, which contacts the track, would be designed to wear down, and be replaceable. (?)
Could not locate any plans on the web...
William Buchanan was the designer of the "999."
40 inch tender wheels?
https://www.msichicago.org/explore/whats-here/exhibits/transportation-gallery/the-exhibit/999-steam-locomotive/
EDITED: 22 Jan 2021 by BEMFARMER
10121.8 In reply to 10121.1
Here is my attempt based on the blueprint and photos of the 999 engine I found on the web. These of course are the small truck wheels and not the large drive wheels.
The blueprint with just the one view is not enough information, but I hope I came close.
The original question was about getting the entire wheel to boolean into a solid. I had no issues with that, or with adding a fillet around the 12 spokes.
We would need to see your 3DM file to help out.
Curves used to make the wheel:
10121.9 In reply to 10121.8
Hi Ed,
Excellent work!
-Brian
10121.10 In reply to 10121.8
those shapes are quite beautiful ed.
10121.11 In reply to 10121.6
Yes, it is for NYC 999.
Chris
10121.12
Let me clarify. I sorted out my problem with the tapered spokes. Yay me. There never was a problem creating a single solid using booleans.
See screenshot. The red arrow points to an area where the fillets need to be very heavy *between* the spokes but not as heavy at the top and bottom of the spoke. I'm sure it's a blend or network or something else I also don't know how to use.
3dm file lives here for your viewing pleasure: https://www.dropbox.com/s/kkldadi27wf7y0t/NYC%20999%20tender%20wheel%20v2a.3dm?dl=0
Chris
EDITED: 20 Feb 2022 by TWOFOOT
10121.13 In reply to 10121.12
Hi Chris,
Very nice wheel.
May I ask where you found the "blueprints"?
Signed by Buchanan, they appear to be originals circa 1893, with some notes from 1919 and 1933.
Presumably when the 86" drive wheels we replaced with 70" wheels, the smaller wheels were changed also.
Spoke count must have changed also?
10121.14 In reply to 10121.12
I looked at some photos on the Internet and there is definitely a web structure joining the spokes on each end. I think the way it all blends together will make it difficult for NURBs modeling - perhaps Sub D is the way to go on this one.
I attempted to make an approximation by creating filler pieces to go between the spokes. Maybe with some additional effort the filler pieces can be sized correctly and made such that they blend into the spokes more gracefully.
Nice poster of the 999. (Original size wheels).
https://www.ebay.com/i/353260486381?chn=
Also found a beautiful scale model, but it only had 7 spokes.
10121.16 In reply to 10121.12
Hi Chris,
perhaps this method may help.
After boolean union spokes to hub select the edge and join.
Add circles sized to the radii you need and sweep joined edge curve.
Trim Hub and blend.
Note when I produced the hub I rebuilt the curved section
so the surface was complete (no seam lines) this helps the blend operation.
Barry
10121.17 In reply to 10121.16
Barry, you are WAY better at Moi than I am. LOL
Is there any way you could show me the process step by step? This is EXACTLY what I need.
Chris
10121.18 In reply to 10121.17
Hi Chris,
you can just use the fillet tool as shown in the photo.
I did the collar trim to give a variable fillet as I was unable to get it with the fillet tool.
I'm basically trimming the solid with a collar produced by sweeping desired fillets.
The sweep path is the edge where spoke joins the hub.
If your still unsure post me your curves and I will mark up what's needed.
Barry
Edit:
It's possible to do it with the fillet tool with variable fillet my problem was filleting across the seam of the hub.
EDITED: 25 Jan 2021 by BARRY-H
10121.19 In reply to 10121.18
Hi
have you try ONSHAPE to do the bevel ?
10121.20
@ Barry-H, how did you get the sweeped circles to meet the spokes and hub at a tangent with your first technique? Or are they just roughly positioned close enough to tangential to suffice?
10121.21 In reply to 10121.20
the circles are snapped to the edge to be filleted.
I used 2 small circles front and back & 2 larger circles on the sides.
Then sweep the edge curve to produce the trim collar.
The blend operation produces a tangent fillet.
Hope this helps.
Barry
Show messages:  1  2-21  22-23
