Camel Perfection
 1-2  3-22  23-42  43-48
10120.43 In reply to 10120.42
Hi Lara,
> Then I thought - yeah - then I noticed the seam...
> What is this?
That's a display artifact from the display mesh having "T" junctures along the edge areas. There may be a couple of pixel dropouts in the shaded display at surface edges.
The export mesher does not make T junctures, if you do a mesh export you should see those will go away:
10120.44
Fine! This is good...Thanks to you All for your patience and help...
A perfect method! :)
Free to you to regulate the Bulge! (here it's a little excessive and of course altitudes of surfaces can be regulated too! :)
EDITED: 23 Jan 2021 by PILOU
10120.46 In reply to 10120.45
Hi Frenchy, thanks for your suggestion. But, malheuresement, this is not the shape I tried to reach...
10120.47 In reply to 10120.46
It's not the shape because above Bases of form Up & Down are not tangent to the Tore!
I will see if that will match! :) (when i will have 5 minutes)
The Blend function is fun but effectively that will not done exactly obtain that you want :)
Maybe the SUBD like shown by Burrman is another possible way... :)
Thread about SUBD : https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
Several faces can be Subdivided in the same time with the same dimension! (here just 2 faces - Up Down one by one)
EDITED: 24 Jan 2021 by PILOU
Show messages:  1-2  3-22  23-42  43-48
