Camel Perfection
 1-12  13-32  33-48
10120.13
wow...
And you can of course in my above example make an Fillet with "Constant" Dist" against absolutly nothing! :)
10120.15 In reply to 10120.14
Pilou, thank you too for your idea and suggestion. Malheureusement je ne comprend pas "everything against nothing" de toi. (My only one french sentence...)
10120.16
I tried to find in the flow concept of the attached file.
When flowing it looks like this. Did a workaround with a sweep, then I got a Triple camel...
EDITED: 10 Feb 2021 by MALA
10120.17 In reply to 10120.16
HI Mala, it doesn't look like the 3DM file was attached.
My example was just normal Boolean Union without any Fillet so can't be more rustic perfect! :)
After if you want fluent transition you can make some fillet or more complex things like "Blend''
(but in this case you must make some trimming around the parts to Blend! )
10120.19 In reply to 10120.16
Hi Mala,
I can't be sure since i didn't see the file to test with, but your result there looks like what would happen if you use Flow to transform just the profile curves and then did a Loft on the transformed profile curves.
Instead you should generate the Loft from the initial profile curves, and you want to flow the lofted object.
10120.20 In reply to 10120.19
Flow is wow-powerful...ok, you know it by yourself...
The loft I made like you Michael, was similar sub optimal like the technic on the bended profile itself. (guess it´s a matter of my skills.)
But what I noticed the first time is the scaleLine-Option in the sweep tool dialogue. Here I was able to bringe a shilhouette line and bring it into the sweep.
The only problem was that the loft was mirroring. I splittet it and flowed it onto the bended spline. Better would be: Not to mirror.
Is it possible not to get the mirror forming? I tried with different placing of the scale line - always mirrored.
Sorry for my hell english...
Lara
10120.21
Is there a workaround to get the flow-object started exactly at beginning of the circle segment?
10120.22 In reply to 10120.21
Normally yes : just put your Base Start Surface where you want it start to the Target surface!
About the subtil difference between CIrcular Fillet and Fillet Const DIstance ;)
About beautiful surface of the Blend Function!
At the end you can modulate the result by Add (and Add / or) Move some points on the perimeters!!!
10120.25
"Normally yes : just put your Base Start Surface where you want it start to the Target surface! "
I picked the base line of the transfer object and the line for the flow geometry normally. No snapping on it´s endpoints possible, I guess in order to get the flow result exactly.
10120.26
CamelTor.
Size: 74.8 KB, Downloaded: 12 times, Dimensions: 491x453px
10120.27 In reply to 10120.21
Hi Mala,
Can you please post the .3dm model file that you're showing in the screenshot?
If you could post the .3dm model file with the piece that is being mirrored that you don't want mirrored that would probably help me to better understand what you're asking here. I can't figure it out from the description and screenshot alone, I need to be able to examine the file.
- MIchael
10120.28 In reply to 10120.25
No sorry there is no problem with the limit of perimeters :)
Start Face : Target Face!
If it's tangent on start, that will be tangent on the target!
It's not marvelous ?
Look in deepth this section! ;)
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
EDITED: 22 Jan 2021 by PILOU
10120.29
Mirroring scale line, file.
10120.30 In reply to 10120.26
Thank you WN. I fear that form has nothing same with the form I need. You may see what I try to reach it in the very first post and image.
Why you don't use the circles as frontier to the curve ?
It's not more easy for control every thing ?
10120.32
im the beginner - you are the pro. I guess you are right, becausce you got the experience.
But I do not know what exactly you mean as frontier? it is not almlost the same? I tried pretty often the circles to modulate (I think this is what you mean). Smoother are my results with the scale spline.
What I dont like is that the peak is so fat. But if I slim the peak - the surface is not so smooth how I need it.
Show messages:  1-12  13-32  33-48
