Custom UI : what is the html code for the Scene Browser "Styles" tab ?
All  1-2  3-5
10119.3 In reply to 10119.2
Hello Michael -
I see, and that probably explains why I was having a hard time extracting it, so to speak. Thank you for the explanations as always :)
On that topic, are there any shortcuts/commands related to the Styles tab ? Like for instance to put the current selected objects inside a given color layer, and hiding/unhiding a Style altogether. This could be very useful for quickly turning off construction guides I believe.
EDITED: 21 Jan 2021 by PIOR_O
10119.4 In reply to 10119.3
Hi Pior,
Yes there are several ways that scripts can access and modify style data.
That would go like this:
script: var style = moi.geometryDatabase.findStyle( 'Green', true /*CreateIfNotFound*/ ); moi.geometryDatabase.getSelectedObjects().setProperty( 'styleIndex', style.index );
That's done by hiding/unhiding objects that have a given style index, like this:
script: /* Hide objects with style = Green */ var style = moi.geometryDatabase.findStyle( 'Green', true /*CreateIfNotFound*/ ); var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex == style.index ) { obj.hidden = true; } }
script: /* Show objects with style = Green */ var style = moi.geometryDatabase.findStyle( 'Green', true /*CreateIfNotFound*/ ); var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex == style.index ) { obj.hidden = false; } }
10119.5 In reply to 10119.4
Hello Michael -
That worked beautifully, as always ! I find myself using only one or two Styles beyond the default Black (to store a few sketched lines and templates) so all I had to do was to assign a few hotkeys. This is working great, thanks :)
Show messages: All  1-2  3-5
