Custom UI : what is the html code for the Scene Browser "Styles" tab ?
All  1  2-5
10119.2 In reply to 10119.1
Hi Pior, the scene browser is implemented as one big custom control that is placed using a <moi:SceneBrowser> tag in HTML.
All of its internals like populating and updating the different sections and handling events and such are all implemented by code inside moi_lib.dll . It's not set up to have just one portion of it yanked out and placed somewhere else so what you are describing isn't very feasible, sorry.
10119.3 In reply to 10119.2
Hello Michael -
I see, and that probably explains why I was having a hard time extracting it, so to speak. Thank you for the explanations as always :)
On that topic, are there any shortcuts/commands related to the Styles tab ? Like for instance to put the current selected objects inside a given color layer, and hiding/unhiding a Style altogether. This could be very useful for quickly turning off construction guides I believe.
EDITED: 21 Jan 2021 by PIOR_O
10119.4 In reply to 10119.3
Hi Pior,
Yes there are several ways that scripts can access and modify style data.
That would go like this:
script: var style = moi.geometryDatabase.findStyle( 'Green', true /*CreateIfNotFound*/ ); moi.geometryDatabase.getSelectedObjects().setProperty( 'styleIndex', style.index );
That's done by hiding/unhiding objects that have a given style index, like this:
script: /* Hide objects with style = Green */ var style = moi.geometryDatabase.findStyle( 'Green', true /*CreateIfNotFound*/ ); var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex == style.index ) { obj.hidden = true; } }
script: /* Show objects with style = Green */ var style = moi.geometryDatabase.findStyle( 'Green', true /*CreateIfNotFound*/ ); var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.styleIndex == style.index ) { obj.hidden = false; } }
10119.5 In reply to 10119.4
Hello Michael -
That worked beautifully, as always ! I find myself using only one or two Styles beyond the default Black (to store a few sketched lines and templates) so all I had to do was to assign a few hotkeys. This is working great, thanks :)
Show messages: All  1  2-5
