moi3d.com web site overhaul underway
 1-17  …  58-77  78-97  98-99
10115.98 In reply to 10115.97
Hi Brian, I guess you probably have a zoom level set?
If you use Ctrl+0 to unset the zoom then is it the proper size when you launch it?
10115.99 In reply to 10115.98
You are correct. I have had two levels of zoom, mostly.
Ctrl+0 allows the two windows to come up showing everything.
The last work you did was an improvement though.
So: User problem SOLVED:-)
Show messages:  1-17  …  38-57  58-77  78-97  98-99
