moi3d.com web site overhaul underway
 1-16  …  57-76  77-96  97-99
10115.97 In reply to 10115.96
Thank you.
The Edit message window is good now.
The Attachments window is better. The three options boxes show up, but the window must be either scrolled, or enlarged to the right, to see the Total Size:, and Free Space:.
Similarly for the Upload New Attachment window, scroll or resize to see Total Size:, And Free Space:.
Size: 129.9 KB, Downloaded: 21 times, Dimensions: 1368x862px
10115.98 In reply to 10115.97
Hi Brian, I guess you probably have a zoom level set?
If you use Ctrl+0 to unset the zoom then is it the proper size when you launch it?
10115.99 In reply to 10115.98
You are correct. I have had two levels of zoom, mostly.
Ctrl+0 allows the two windows to come up showing everything.
The last work you did was an improvement though.
So: User problem SOLVED:-)
Show messages:  1-16  …  37-56  57-76  77-96  97-99
