moi3d.com web site overhaul underway
 1-20  …  41-60  61-80  81-99
10115.81 In reply to 10115.80
thanks michael, that option is checked. don't waste your time on this. i thought something changed. but if not, then it's just my memory. i think before i always used the desktop site and the images were large and i just scrolled around. maybe the only difference is now the images fit in frame, which people asked for and is nice.
Hi Michael
I've been exploring all of the CSV file import and export posts.
The old SavePointFile script, circa 2008, with ActiveXObject, works for MoI3, but did not work for MoI4, Windows 10.
(The old ImportPointFile script did work with MoI3.)
Your newer UpdatedSavePointFile.zip script works with MoI4, Windows 10, (and apparently with OSX, as your posts have indicated).
http://kyticka.webzdarma.cz/3d/moi/#SavePointFile
Perhaps this link should be edited to deprecate the old version?
I've renamed my copy of the old version to ...OLD, and maybe should delete it.
And installed your Updated version to commands folder. (In my case, AppData commands folder for non-"stock" commands).
(I did not try newer version on MoI3...
EDITED: 6 Feb 2021 by BEMFARMER
10115.83
Forum emoticons [Preview] dialog did not load:
http://moi3d.com/forum/display_emoticons.php?webtag=MOI&pack=
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
10115.84 In reply to 10115.83
Hi Mindset,
Seems to be a casualty from the switch from PHP5 to PHP7 back several months ago, should be fixed now. Thanks for reporting it!
10115.85
When will the "whats new" page be updated? :P
10115.86 In reply to 10115.85
Hi Chris, I hope to get to that sometime this next week.
10115.87 In reply to 10115.73
Updated mobile forum - "Show messages" nav bar for long threads now shown at top of messages in addition to at bottom.
Mobile forum updated - guest logon enabled.
10115.89 In reply to 10115.87
Michael
Thank you for doing this, much appreciated!
Andrew
10115.90 In reply to 10115.89
You're welcome Andrew! - Michael
Updated forum for mobile - new option under Options > Forum Options > Mobile > "Redirect to light version on mobile devices" checkbox.
By default it's on but If unchecked then it won't automatically redirect you to the mobile version.
Another update for forum mobile version, some tuning of the messages display.
I think I'm done updating the forum for now.
10115.93 In reply to 10115.92
A minor matter:
It would be nice if the "Upload new attachments" and "Attachments" windows opened to show all of their contents.
Currently on my (HiDef) screen, the two windows have to be dragged to be larger to see their text.
10115.94 In reply to 10115.93
Hi Brian, can you please show a screenshot of what they look like over there when first opened?
10115.95 In reply to 10115.94
Here are two snagit png's of the Attachments window and Upload window, just opened.
Size: 109.2 KB, Downloaded: 37 times, Dimensions: 1362x732px
Size: 97.5 KB, Downloaded: 34 times, Dimensions: 1485x1050px
10115.96 In reply to 10115.95
Hi Brian, re: attachment windows - I think I've got those tuned up now, are they behaving any better?
10115.97 In reply to 10115.96
Thank you.
The Edit message window is good now.
The Attachments window is better. The three options boxes show up, but the window must be either scrolled, or enlarged to the right, to see the Total Size:, and Free Space:.
Similarly for the Upload New Attachment window, scroll or resize to see Total Size:, And Free Space:.
Size: 129.9 KB, Downloaded: 21 times, Dimensions: 1368x862px
10115.98 In reply to 10115.97
Hi Brian, I guess you probably have a zoom level set?
If you use Ctrl+0 to unset the zoom then is it the proper size when you launch it?
10115.99 In reply to 10115.98
You are correct. I have had two levels of zoom, mostly.
Ctrl+0 allows the two windows to come up showing everything.
The last work you did was an improvement though.
So: User problem SOLVED:-)
Show messages:  1-20  21-40  41-60  61-80  81-99
