Filleting a Böbbel
 1-7  8-27  28-47  48-60
10113.8 In reply to 10113.7
Hi Mala, try the attached version.
I used a trick to export this joined curve out to SAT format which will fuse it together into one piece, then re-imported it, revolved it and trimmed it:
That gets rid of one edge coming off of that difficult corner spot which will help it to be able to fillet:
10113.9
What a wonderful and elegant trick! And I worked through one of them and certainly didn't dare ask myself because I couldn't manage it.
In any case, that saved my day and so did other others ...
Thank you very much ... maybe I should use the SAT trick on "Modeling a Böbbel" ...
Best, and thanks for Saturday-Work...Mala
Funny trick!
10113.11 In reply to 10113.10
Yes indeed!
10113.12
Hello, filleting new edges:
Would you please take a look at this geometry. I tried to filleting edges. But it didn´t work. Also the ExportImport-Trick didn´t work.
Ideas?
Best, Mala
EDITED: 10 Feb 2021 by MALA
10113.13 In reply to 10113.12
Hi Mala, re: filleting - there's a few different things going on there. One is that your object is made up of several separate surfaces, you need to join those together for the filleter to be able to do anything on those edges. You can't fillet a "naked edge", meaning one that is not joined between 2 faces.
Then the other thing is you don't want to have things like faces that are part of the same plane to be diced up into pieces, you need to make one large plane for those spots instead of having fragmented faces. I'm referring to these areas here:
The other thing that I did is to make this spot be a revolved surface that intersects with these planes rather than having it be built by Network which makes for some awkward shaping in it:
So try with the attached version it should fillet better:
For find naked edges...
script: /* Show Naked edges*/ var gd = moi.geometryDatabase; gd.deselectAll();
var breps =gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i )
breps.item(i).getNakedEdges().setProperty( 'selected', true );
EDITED: 25 Jan 2021 by PILOU
10113.15 In reply to 10113.14
(Sry. for delay...had a switch of my internet conections...)
Using the script shows the complete desaster of my modelling. Almost all lines are highlighted...hmmm´...I will work through Michaels flow...
Obviously the connect and bool/connect command do not stitch every surface together. I must try to look behind this...
10113.16
First of all thank you Michael for the way you showed me.
I had to reconstruct it and now I got two problems:
Altthoug the scipt of Frenchy tells me "noLostEdges at the filleting seams - I cannot do the fillet. Tried pretty much...where is my mistake?
And...I tried the workflow bending the geometry and it was ok. But now the geometry is at opposit site. Is there a simple way to bring it vice versa like at the screenshot sketched?
10113.17 In reply to 10113.16
Hi Mala, so if I understand correctly you are trying to fillet the object in Goal.3dm with these edges? :
The main thing that would help to make filleting possible there would be to make these into just one longer surface instead of fragmented into multiple pieces:
The corner here will be difficult for the filleter to handle:
But if this edge was not there it would help:
Sorry I'm not understanding this part.
<< Is there a simple way to bring it vice versa
Use the mirror function ?
10113.19
I redrawed but I still cannot filleting the relevant edges.
The script told me the filleting edges are not naked...no idea anymore...
10113.20 In reply to 10113.19
Follow the Michael steps for build your object!
10113.21 In reply to 10113.20
I guess I was pretty near to his suggestions.
10113.22
Workflow wrong?
Gererally - is it the wrong operation to cut a geometry with a line or cube/boolean in order to get a spline? I split/cut/bool, then I mark the spline, copy and paste it - give it a name...and then the spline description points are so many?!
Is this wrong and may this be the issue for my bad modelling?
10113.23 In reply to 10113.21
yes but your own model has some edges "segmented" for any reasons!
When you have such number of points for a curve (circle above) : Press TAB and write Rebuild for a reasonable number!
10113.25 In reply to 10113.22
Hi Mala, there are some problems with the model, a couple of things I noticed were edges broken up into small fragments:
And some areas where edges are not meeting very precisely:
So yes your process here is not making optimal geometry.
Well it depends on what you're going to do with it but if you're repeating these kinds of operations on splines through several iterations that's probably not so good.
I also noticed you have some "non-optimal" shall we say construction here:
It's odd that the surface has that slanted construction to it, it's better for the surface here to have a planar end and to have the slanted areas be cuts on it.
One of your other surfaces is set up like that but not this other one.
10113.26 In reply to 10113.22
Hi Mala, what is your construction method for this piece here? :
With it being slanted it would probably be good for it to be extended so it can intersect the other surfaces.
10113.27 In reply to 10113.26
I'm trying to figure out your design intent for that area, is it supposed to have a non-uniform shape to it? :
Or should that be an even surface of revolution (a piece of a regular cone) that is just rotated?
Show messages:  1-7  8-27  28-47  48-60
