Filleting a Böbbel
 1-5  6-25  26-45  46-60
10113.26 In reply to 10113.22
Hi Mala, what is your construction method for this piece here? :
With it being slanted it would probably be good for it to be extended so it can intersect the other surfaces.
10113.27 In reply to 10113.26
I'm trying to figure out your design intent for that area, is it supposed to have a non-uniform shape to it? :
Or should that be an even surface of revolution (a piece of a regular cone) that is just rotated?
10113.28 In reply to 10113.27
I made this sweep:
EDITED: 10 Feb 2021 by MALA
10113.29 In reply to 10113.27
I think I'm understanding that the design intent is for there to be even distance between the angled cuts and then that cone-ish shape is filled in between those.
10113.30
This is the new confusion base I begin from. I know this looks not very good...
10113.31 In reply to 10113.29
The goal is the right object.
Left is the construction, then on the right side it is bended. (normally it is perfect in geometry)
The only thing is that the direction of the lower thinner part should be mirrored to the other side. That is what I asked some questions ago. This is the reason why the new drawing goes to the other side then before.
10113.32
Previous question from Michael, answer: I cutted it out by a cube
10113.33 In reply to 10113.32
Hi Mala, how about this attached version, is it correct?
10113.34
puh...I fear yes...and that you needed just 7andAHalf minute...?!
In order to test it I have to expand it. Is it possible without a seam?
10113.35 In reply to 10113.34
My expanding result. Made with extrusion tool. I hoped to pick the points in order to move the border line. No points to pick...I do not understand such things. Sometimes you may see the points of surfaces or objects, sometimes not...
10113.36 In reply to 10113.35
No...It has not the right direction...difficult to explain
10113.37
Another Idea: Is it possible to redirect the direction of a spline in MoI?
10113.38 In reply to 10113.37
Press TAB and write Flip
Will be visible only on Functions who have not automatic linkage!
Yes in Line Web, Not in Loft (curve will be inversed but not the result of the Loft!
Here the LineWeb...Top LIne is "Fliped" before call the LineWeb (on right side)
EDITED: 28 Jan 2021 by PILOU
10113.39
This is the mistake:
10113.40 In reply to 10113.39
About the mirror...
10113.41 In reply to 10113.40
Hi Pilou...not sure what you want so express. Mirroring doesn´t solve the direction problem of the geometry. I tried every mirror variations thats possible. But thank you...
10113.42
My Workflow - I guess you find it pretty pooooooor.
10113.43
last 2 steps
10113.44
Still no filleting possible. Do not no where the problem is. But the geometry is correct now.
10113.45
Added the bended version which is the main geometry I need.
Show messages:  1-5  6-25  26-45  46-60
