Problem with y-joint pipes
 1-5  6-22
About thickness nothing more simple!
As that was solid : kill the caps
Shell
et voilĂ  :)
Hum hum the internal part is some curious at the cross must be another thing! :)
EDITED: 9 Jan 2021 by PILOU
10104.7 In reply to 10104.4
Hi Rebo
i dont understand what does not work for you
here a test with differents angles .
Chri
EDITED: 9 Jan 2021 by CHRI
Size: 37.3 KB, Downloaded: 24 times, Dimensions: 738x727px
Size: 68 KB, Downloaded: 30 times, Dimensions: 1087x577px
10104.8 In reply to 10104.7
Cool colorised managment of tutorial!
10104.9
Hi all.
There is such a way.
https://yadi.sk/d/o4WSigGj7A2d7A
Size: 452.5 KB, Downloaded: 45 times, Dimensions: 2761x2037px
10104.10 In reply to 10104.4
HI
i have change files in 10104.7 post
an explanation with pink line method ( and red line ! )
Chri
10104.11
Hi guys,
I think I got it now! Many thanks for the help, especially to Christian and Frenchy Pilou (and all others too). I appreciate this help very much, you guys are great !
Maybe another process ...not so evident! :)
- difficulty is the Shell & Fillets (External-Internal) don't work very well for the global object!
so...at the end that must be a solid! :)
The 3dm file
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/y.3dm
EDITED: 11 Jan 2021 by PILOU
10104.13 In reply to 10104.12
Not so easy !
Chri
EDITED: 11 Jan 2021 by CHRI
10104.14 In reply to 10104.13
Indeed! :)
You have not made the internal fillets but seems they work also fine!
10104.15 In reply to 10104.14
hi frency,
just a fyi
on the last video you show, of the interior fillet. it's going to a point. that's not realistic. no process would have a point there. it would have to be some other shape. preferably a smooth one, lol.
10104.16 In reply to 10104.15
@Anthony
Sorry i don't know about what point do you speak ???
I have truncated 2 branches for more easy understand what is the internal Fillet
Before Fillet
After Fillet
After Fillet
Before Fillet
10104.17 In reply to 10104.16
hi frency. the last pic. where all three fillets go to that point. i'm not sure that is realistic. i'm not an expert though. put points in fea cause stress concentrations. in real life parts fatigue failures. from a manufacturing point of view, i don't think it's possible to create a point or a straight edge for that matter. CAD takes a lot of liberties. not sure what the op is trying to do though. it's an esoteric thing. not sure if it's relevant here. but something to watch out for if you are building real things.
Say you are in Pipes better for have better flow no sharp singularity! :)
(water, wind, gaz, etc...)
It's for that i fillet the internal parts! :)
We are in 21 th century! ;)
Smooth is beautiful! :)
like this one
10104.19 In reply to 10104.17
hey frency,
i don't have moi v4 yet. but i used the cad program i have. i built a similar model and it looks like that works out to be tangent. so it's probably fine. in the pics and videos it looked like it was sticking up. just a visual thing i guess.
10104.20 In reply to 10104.19
In fact the Fillet (external, internal) are dependent of the thickness so it can take measures inside a range more or less possible...so more or less tangent...
10104.21 In reply to 10104.20
i tried to take pictures of it, but couldn't get a good angle. but basically it looks like three circles coming to the same point. so i think it would always be tangent in that case. but viewing it in cad, at various angles, it looks messed up. you can only see it's tangent from a side view. as soon as you rotate off a little, it looks like the fillets are rising up to a point. it was pretty challenging to make. it made me wonder if there is an n-gon patch in mecway. i tried to do something a little more like what i was thinking, but couldn't patch something that complex.
so with that pipe model. if you put a cylinder through the center and cut out a circle. then fillet everything. then try to patch the holes. that's what i was thinking was going to be needed. fortunately, it wasn't that complicated. just the fillets seem to be ok.
10104.22 In reply to 10104.21
yes it's very curious that is very hard to give a tickness to this simple surface! :)
Show messages:  1-5  6-22
