Problem with y-joint pipes
 1-19  20-22
10104.20 In reply to 10104.19
In fact the Fillet (external, internal) are dependent of the thickness so it can take measures inside a range more or less possible...so more or less tangent...
10104.21 In reply to 10104.20
i tried to take pictures of it, but couldn't get a good angle. but basically it looks like three circles coming to the same point. so i think it would always be tangent in that case. but viewing it in cad, at various angles, it looks messed up. you can only see it's tangent from a side view. as soon as you rotate off a little, it looks like the fillets are rising up to a point. it was pretty challenging to make. it made me wonder if there is an n-gon patch in mecway. i tried to do something a little more like what i was thinking, but couldn't patch something that complex.
so with that pipe model. if you put a cylinder through the center and cut out a circle. then fillet everything. then try to patch the holes. that's what i was thinking was going to be needed. fortunately, it wasn't that complicated. just the fillets seem to be ok.
10104.22 In reply to 10104.21
yes it's very curious that is very hard to give a tickness to this simple surface! :)
Show messages:  1-19  20-22
